sumit426
HyperForm Meshsing optimisation
Hello All,
I am meshing some sort of symmetrical blank component, but using by B-mesh and also with Automesh I am not getting any symmetrical meshing, What to do to optimize the meshing element, Is there any kind of Advance meshing editing tool to change or edit the meshing element along the line/path in the existing mesh? if so or any other tool is there please suggest for the same.
(I have added the pic of component)
Thanks
Hi Sumit,
You can trim this geometry on the plane of symmetry using Surface Edit tools (Geom>Surface Edit) and mesh the half model as desired. Using the Tools>Reflect option, you can  reflect the created mesh to the other surface.
Please go through HM-3100: AutoMeshing tutorial in Help Menu which shows many options in Automesh panel
