Corentin
Material Law Characterization with RADIOSS
I am trying to "fit" a curve (from a simulation) to a compressive test of a rubber. Using the LAW42 (Ogden formulation with "mu and "alpha").
I don't really understand how the "request" and "component" options work when I want to create a vector. As you can see in the attached screenshot.
And I don't have the "tensile_test..." file as mentionned in the tutorial (in the picture) to check it. Thus, I can't figure it out how it works...
I just know that I need the Force and the displacement from the simulation, but with which type of file (.txt? .rad? etc...)
Can you help me please?
Thanks,
Regards.
Corentin
Once you able to run nominal run for Radioss solver it would generate T01,h3d result file which you can pull using File source or If you have access to latest 2017 /14.0 version you can use file assistant for same.
