Sign in to follow this
yao
How do I set up ssh to enable password free logins for use with HP-MPI?
HP-MPI requires a remote shell command to spawn remote processes. AcuSolve allows users to select this remote shell via the -rsh command line parameter. This allows users to use standard UNIX/Linux utilities such as rsh or ssh in addition to custom wrapper scripts that may be necessary on some systems. Although this provides a high level of flexibility, most systems simply use ssh to perform the remote shell calls. However, this requires that the system be set up to permit password free logins. To accomplish this, the following procedure should be followed.
Execute the following sequence of commands from a shell prompt:
$ ssh-keygen -t dsa
Press return when prompted for a password (i.e. leave it blank).
$ cd ~/.ssh
$ cat id_dsa.pub >> authorized_keys
$ chmod go-rwx authorized_keys
$ chmod go-w ~ ~/.ssh
$ cp /etc/ssh/ssh_config $HOME/.ssh/config
$ echo "CheckHostIP no" >> $HOME/.ssh/config
$ echo "StrictHostKeyChecking no" >> $HOME/.ssh/config
It may be necessary to repeat the above procedure using rsa instead of dsa (i.e. ssh-keygen -t rsa)
