Sign in to follow this
s-theldd
Magnetic Field Density in empty Space
Hey, i have kind of like a U-shaped construction with magnets and i want to see how homogenous the magnetic field is inbetween.
My problem is, that the only way i know how to do it at the moment, ends in an unusable result because the infinite box blocks the view, since the area around and in between is the same.
Can someone tell me how to do it, or a little workaround?
Greetings
Thomas
You can set the infinite box invisible. To do it:
  1. Geometry
  2. Domain
  3. Infinite box
  4. Right click, set invisible
With this you can see just a Flux line (isovalues) of your device without infinite box.
Don’t hesitate to contact us again.
Best regards.
