Udhay Rohith
1D spring stiffness
Hi All,
I want to create spring element for my model. I have created using spring section in hypermesh and used CELAS1 element. I need to define Spring stiffness. For that I have used Property with Spring gap type and PELAS as a card image. Here comes my problem, I need to give 10N/mm stiffness to spring. In property card whatever values I give it to K column, the displacement is same. It is not taking as stiffness. I do not know how it is calculating or  any thing I have missed. Please help me on this?
Hi Udhay,
I tried on a simple CLEAS1 element and as the stiffness changes I see change in displacement.
Can you share the model file with us?
Please note: If you are a commercial customer, you can also contact your local support http://www.altairhyp...ortProduct.aspx
20 minutes ago, gopal_rathore said:
Have you made a Local coordinate system for the spring and then make the dof update for spring in the same direction of its axis. This should work I think.
I think this may help. Maybe the orientation is an issue with the CELAS element in your element.
sir how to apply spring with damper in my model that actually simulate as a rear suspension of  a motercycle
how to give orientation in a 1d>spring panel
and what represent these dof 1,dof2 .. .. .. .. dof 6
help me
