Hi All,   Please find attached tutorial for CFD optimisation of a manifold.   Some of the applications, where it can be used includes,   HVAC ducting • Reduce pressure drop • Increase flow uniformity • Maximize/minimize outlet temperature Heat exchangers • Maximize pressure drop • Maximize heat transfer Brake discs • Minimize temperature • Maximize heat transfer • Brake cooling ducts External Aero • Minimize drag • Maximize negative lift
