GA_Peach0511
TCL Script will not run in Command window using hmbatch
I receive the below error when I try to run my tcl script in hmbatch mode. This same script however will run when I run it inside of Hypermesh using the scripting toolbar and gets no errors. I would like to run this in batchmode.
======Shell AR Distribution: max=3.91=====
   [AR=1~1.5]: et cnt=200
   [AR=1.5~2.25]: et cnt=552
   [AR=2.25~3.38]: et cnt=35
   [AR=3.38~5.06]: el cnt=1
8 #0 star shape failed at enclosed stage
Any suggestions? I have attached the tcl script.
Base_shrinkWrap.tcl
could you try running batchmesh by this command from windows command prompt:
...\altair\14.0\hm\bin\win64\hmopengl.exe -batchmesher -noconsole -tcl "...path\to\Base_shrinkwarp.tcl"  "path\to\hmfile.hm"
