Sign in to follow this
jahnavi
rms stress and psd elemental stress
Sir generally RMS means squaring each value adding them up and square root of that value.is it not same here?? Can u  pls tell about RMS cumulated also.
thankyou. sir  we can see the stresses only on elements on the surface.what about other elements .if we select select some elements through window can we find thee element having maximum stress in that region
@Jahnavi,
One way is to have a shell coat with minimal thickness over solid elements and run the analysis.
I will check if there another way to do that and will update the same with you soon.
what will be the unit & calculation method  of PSD stress .
If I quote von mises stress under PSD stress then what result I can interpret
Thanks in advance.
