Sign in to follow this
keerthan n a
3D meshing of an assembly
HI,
Can anyone inform how to start meshing the component which i have attached with this post..and give connectivity between two?
It is like a cylinder,  one component inside another in contact. If i mesh both components separately how will i give connectivity? Is it possible to connect them using 'faces' option? Just give me a basic idea. I have worked on plate structures using mid-surface. i have no idea about solid structures.
And how do i use boolean operation to combine them both? Not able to select the components to combine...
Can  use multi solid option in 3D>solid map to mesh this structure..?
Thanks in advance. Please reply.
post-9096-0-46977800-1375881557_thumb.jp
