ACP
Relaxation factor
Generally, value between 0.2 - 0.4 provides good balance between achieving small progression of solution and extra compute time needed to achieve the convergence.
ACP likes this
Nice Question...!
For simple problems, you can keep the value of relaxation factor at its default one.
As relaxation factor works on suppressing the solution (from previous iteration), surely it is going to take a lot of time. Taking the project span into consideration, you have to use it when it is really needed.
ACP likes this
I was going through some research papers, where q-p relaxation method was mentioned for topology optimization.
Where q- Relaxation parameter and P - penalization parameter.
So, I would like to know, how to co-relate these q & P parameters with the parameter being used in optistruct for topology optimization.
Thanks
