Hello everyone, I'm trying to import the pressure distribution around a wing from a file csv by using linear interpolation in pressure tab. I've expected the pressure field to act around the wing surface. But the after the pressure is created, the pressure field is acting in the inner surface of the wing ( you can see the picture I attached below). Why is that happening? And how can I change the direction of the pressure distribution, so that, it act around the outer surface of the wing?
Could you guys help me please? I'm very appriciated any help I can get. Thank you very much!
I'm looking forward to your respond!
P/s: I've also attached the .hm file and the pressure.csv file
pressure-4.csv
wing.hm
