Linear Static Analysis.
I have attached a running board linear static analysis. I’m getting a deflection of about 0.0053mm deflection. But in real scenario they are experiencing 1 to 5mm deflection. Instead of applying load on REB3 if I applied load as a point load (single point in the middle of 200 x 80 mm) I’m getting deflection of 3mm. So what should I do here? Should I use REB3 or point load for a cross section of 200 X 80 mm
Thanks,
Vijay
Can you check the area of the load applied?
Are you dividing the load by any chance by number of nodes?
