Ildar
Some mistake in meshing
Without Periodics the meshing is fine, but I need mesh with Periodics
This is the error, when meshing with Periodics:
Quote
C:\Program Files\Altair\13.0\acusolve\win64\script\Console.zip\pnlAmsExport.py:428: DeprecationWarning: raising a string exception is deprecated
Traceback (most recent call last):
  File "pnlWin.py", line 943, in funcTool
  File "pnlTools.py", line 244, in toolGenMesh
  File "pnlToolsAcuMeshSim.py", line 120, in __init__
  File "pnlToolsAcuMeshSim.py", line 463, in genMesh
  File "pnlToolsAcuMeshSim.py", line 576, in exportAmsFile
  File "pnlAmsExport.py", line 431, in exportFile
pnlAmsExportError: 'Error from ams export module: <error mapping pbc faces> '
What was the CAD file format you imported into AcuConsole? Periodic meshing in AcuConsole works with "real" CAD formats like Parasolid, CATIA. It is not meant for STL file. In your case it seems to be a STL import.
 These faces do not have "matching" geometry for some reason. One option here would be to import the CAD files into SolidThinking Inpsire (part of HyperWorks full installation) and export as parasolid. In general the parasolid export from Inspire is robust for AcuConsole.
I had use the Parasolid file format. I have the problem with Periodics meshing.
Sborkasnarostom.x_t
6 hours ago, Ildar said:
The another model with the same problem. CAD was built in Hyper Mesh
sector-1gr-100mkr-hm.hm
sector-1gr-100mkr-hm.x_t
sector-1gr-100mkr-hm-001.acs
CAD export from HyperMesh is not always compatible with AcuConsole. As I mentioned earlier, Parasolid export from either a CAD software (CATIA, ProE, NX, etc) or Inspire is the best option of importing CAD file.
