zyuce
finding holes and creating rigids
Hello All,
I am trying to create rigid elems for a spesific shell component with holes on it.
In documentation I have discovered *finholesinit tcl command. However I can not obtain line number also I can not define center of circle using tcl automatically.
How can I achieve this problem?
Hello Tinh!
I have checked the reference guide but I could not find a command as;
hm_holedetectioninit
hm_holedetectionsetentities elems 1
hm_holedetectionsetholeparams hole_shape=31
hm_holedetectionfindholes 1
Can you share if you have a document about these commands?
This script may also help you, which allows the user to select comps that have holes in it, select a search tolerance, and it will then find all of the holes within those tolerances and then automatically create spiders in each of those holes.
You can download the script from: https://connect.altair.com/CP/script-list.html
