Sign in to follow this
RishabhAwasthi
default settings saved in a template file
Hi all,
I have a query regarding the default settings under the preferences tab in Simlab 2017. Is the default settings saved in a template file(.xml) or some other format which can be accessed by the user and altered later according to the requirement. I have to re-visit preferences tab to change the settings.
Regards
Rishabh
Two ways you can achieve this.
Check .ini file in below location.
C:\Users\rahulr\.Altair\SimLab_V2017\simlab
or
create environment variable with name
SL_USER_DEFINED_SYSTEM_SETTING_FILE
and pointout .ini file path.
