Fedra853
Problem importing FLUX file
I'm trying to import a file from FLUX software, I export the geometry from FLUX in .IGES and .STEP. In both extension the imported geometry in hypermesh is uncomplete, some solids there are, other no. some lines are ok, other are free lines with no connection. I found a lot of problem in rebuilt the geometry with no succes.
How can i fix this problem? is there someone how can works with both programs with no problems?
Grazie!
I mean did you try exporting files from flux in parasolid format & then importing in Hm. Also if possible share that file to crosscheck same at our end.
yes, i tried all the exporting extension that FLUX permit, the result it's more or less always the same. There is no possibility to import in hm directly the original flux file?
