Sign in to follow this
Simonec
Default damping in Optistruct
does Hypermesh use a default damping factor for harmonic analysis if I don't manually set one?
I need to compare another frequency response without damping and I need to know if the response obtained with Optistruct has or hasn't damping in it.
Thank you
Hi @Simonec
HyperMesh/OptiStruct does not have any default values. All are user defined values.
You can introduce uniform structural damping using Control Cards>> PARAM>> G.
Where G is 2*Critical damping ratio (C/C0)
