Sign in to follow this
hvp9 freezes
Hi
I'm using hvp9 with Win XP Pro SP2. (HP 2210b notebook)
When h3d is selected by the file open, hvp9 freezes.
Do you have the same problem?
Therefore I tried the debugging of hvp.exe .
Then warning was occurred.
Exception code E06D7363
EIP 7C812A5B kernel32.7C812A5B
hvp8 does not have any problem.
May there be a problem in a source code of hvp9?
If you know it, please let me know.
Can you reduce the graphics aceleration and try...
If this does not work please let me know a few details as below:
1.What is the size of this H3D file?
2.What is the graphic card on your machine?Do you have the latest driver?
3.Is it a standalone installation of HVP or do you have the complete hyperworks suite installed?
Yes. I moved a slider.
"Basic accelerator functions: Use this..." or
"No accelerator functions: Use this..." are no problem.
However, hvp8 does not have any problem.
Only why, hvp9?
1. H3d file is "rotor.h3d" in demos/hvp folder. 286KB.
2. Graphic chip is "Intel 965 Express Chipset" on notebook. I have the latest driver.
3. This is a standalone installation of hvp.
regards
