Sign in to follow this
pioborzy
Non managed error which has stopped solving process
I can't solve the problem with model prepared in HyperMesh and exported to Flux.
Model consists of two cylindrical coils on yoke, a solid conductor below them and the surrounding tetrameshed air.
Analysis is set to magnetostatic.
There is no non-linearity in any material
Chesk physics doesn't give any error.
Whenever I start to solve problem, Flux gives:
"End of physical check.
12:03:00       9 sec. Start save ...
12:03:00       9 sec. ... end save
Active formulation(s) :
MS3SCRHJ : Magnetostatic scalar potential reduced versus Hj formulation
MS3SCA : Magnetostatic total scalar potential formulation
Matrix system : linear, real, symmetrical
12:03:01      10 sec. Start solving problem ...
Step number 1
12:03:02      11 sec. Start reading ...
12:03:03      12 sec. ... end reading
12:03:03      12 sec. ... end solving problem.
Closing project
Close of E:/(.....)
... end closing project
Can not execute the following command :
Scenario['REFERENCEVALUES'].solve(projectName='proba.FLU')
executeAlgo_c : Execution failed.
Failed execution
executeAlgo_c => failedstdcom.error.SoftwareFortranException: executeAlgo_c : Execution failed.Failed execution
quite long list of which execution has failed.
Closing project
Maximum use of 3623 MiB. in numerical memory
For the dynamic table ID 1127406
Maximum use of 6 MiB. in character memory
For the dynamic table ID 1073214
   NUMZM         ADRES    SUIV    PREC    CODE          LONG           UID     PROP4   ...
       1             5       6       4   R08 5             0             0
       2             1       5       5   C80 8             0             0
       4    2941622223       1       6   R08 5             0             0
       5       5496560       2       2   C80 8             0             0
       6             5       4       1   I04 2        600037             0
Numerical memory: Total length                   =2941622222
(8 byte words)    Present length                 =    600041
                  Useful length                  =    600041
                  Number of numerical arrays     =         3
Character memory: Total length                   =   5496559
(80 byte words)   Present length                 =         0
                  Useful length                  =         0
                  Number of character arrays     =         2
Maximum number of arrays (num+char)              =    100006"
Any idea where could be the problem?
Thanks
Piotr
Can you check the formulation that you use?  (in the application try to use automatic formulation)
If the problem persiste can you send me your Flux project (asoualmi@altair.com)
Thanks
