Matthieu
Is there a way to split lots of 1-D elements all at once
Hello everyone,
I am currently working on a lattice structure made of beam elements and I would like to split all those elements into two, in order to increase the mesh's density. So far I have found how to split 1-D elements by drawing a line... but considering there are close to 26 000 elements, this method is definitely not ideal here !
So my question is: is there an easy way to select all the 1-D elements and split them into two "in one click" ?
Thank you in advance for your time.
Matthieu
Hi
a simple Tcl script may help you:
*createmarkpanel elems 1 "Select 1d (bar2) elements:"
*createmark elems 2 "by config" bar2
*markintersection elems 1 elems 2
set ENum  [hm_marklength elems 1]
if {$ENum} {
     eval *createarray $ENum [lrepeat $ENum 2]
     *elementmarksplitwith1D 1 1 $ENum
*clearmark elems 1; *clearmark elems 2
Rahul R likes this
Thank you for your answer; I will look into it (might not be instantaneous since I started using HyperWorks only a month ago)
Matthieu
Hi Matthieu,
Here is a macro for splitting 1D elements in 2 in one shot . I hope it will solve your problem and time
*createmarkpanel elements 1 "select beams to split"
#set elem_list [hm_getmark elements 1]
set num [hm_marklength elements 1]
hm_commandfilestate 0
hm_blockerrormessages 1
hm_blockmessages 1
*entityhighlighting 0
hwbrowsermanager view flush false
eval *createarray $num [string repeat "2 " $num]
*elementmarksplitwith1D 1 1 $num
*entityhighlighting 1
hm_commandfilestate 1
hm_blockerrormessages 0
hm_blockmessages 0
hwbrowsermanager view flush true
Rahul R and tinh like this
