Hi sir,
I am getting an error while solving FRF analysis, i.e.
*** ERROR # 2094 ***
 EXCITEID on RLOAD2 # 9 data references follower force or nonexistent
 DAREA/static loading with ID # 4.
 There were 2 error messages during input processing.
  The first message is repeated below:
 ==== End of solver screen output ====
 ==== Job completed ====
Please help me, as I am running out of time.
Regards
Rajendra Prasad
Borgwarner
Thanks for reply vikas,
inputs are
Freq range: 50 to 500Hz.
Gravity: 2G
Damping: 2% & 4%( 2 simulations)
Loads I applied are
At the place of constraint, SPCD loads are also applied in all 3 dimention( towards specified dirc, 9810 N/mm2, load is applied).
Tabled1 is applied, range of freq 50 to 500Hz & gravity 2G is applied
Tabdamp is applied for damping i.e 2%
RLoad2 applied to merge SPCD load and Tabled.
Load step
Rajendra
On 8/29/2017 at 11:06 AM, vikas kenchapur said:
Hi Rajendra,
Apologies for the delayed response
Could you please set the TYPE to ACCE on the RLOAD2 card and re-run the job
Thanks
Vikas
Still error is showing
