Sign in to follow this
Prateek Gupta
Export model from Hyperview to Hypermesh
I have done a topology optimization on a small component and want to do size optimization on the obtained resulted structure. So How can I export model (after removing the desired material) to hypermesh?
Hi Prateek,
Have a look at this. You can use OSSmooth to get the optimized model or as CAD format in HyperMesh
On 6/30/2017 at 1:39 PM, Prakash Pagadala said:
Hi Prateek,
hey Prakash thanks for the help.
one more problem is there when I do size optimization of a simple plate there no error came and the result is clearly in hyperview.
but when I do perform the same thing on a different structure it is not showing the result. Here I'm sending the ".hm" file of my problem.
can you please see n tell me where I had done wrong.
single_lug_2D_size.hm
