Sign in to follow this
Korosh
Problem to import Radioss Example
Hi my Dear
In the hyperwrks Tutorials have some Example (//Altair/Demo/hwsolver/radioos) that have been Zipped,
I copy folder to another Drive and extract there, then Run Radioss and to use Import Solver for that extracted flie.
but after import , I Have Some warning, like below:
Warning:  starter Input Deck contains Keyword  /SHFRA/V4
 which is CURRENTLY UNSUPPORTED in HM present at line number 38
Warning:  Unsupported information found in input deck
                Resolution:  Unsupported text written to file: C:/Users/Home/Desktop/09_Billiards/Contact_modelling/Inter_16_sliding/TEST16S_0000.rad0.hmx
Warning:  starter Input Deck contains Keyword  /SHEL16/11
Please help me for solve this problem.
Bestrigards.
Hi Korosh,
Which HyperWorks version are you using?.Since this is an obsolete card you are getting this warning.
I tried the same in HyperWorks 14 and HyperWorks 2017 version and I didn't get any such warnings.
I have, HyperWorks 14 and HyperWorks 2015 version.
After Import by Radioss Block140 , I have a massage at Hmx File:
$ Extra Data for RADIOSS from E:/48_solid_spotweld/solid_spot_law59/FRAME_MODIFIED_0000.rad using C:\Program Files\Altair\14.0\io\model_readers\feinput\bin\win64\radiossblk.exe.
$ File Input to HyperMesh on 07-08-2017 21:14:29.
## File: E:/48_solid_spotweld/solid_spot_law59/FRAME_MODIFIED_0000.rad, Line: 399 -- The Keyword listed below is currently unsupported
//SUBMODEL/1
# sub-model title
Part 1
#  Off_dft   Off_nod   Off_elt  Off_part   Off_mat  Off_prop
         0         0         0         0         0         0
after that massage i Run " radiossblk.exe " but my problem didnt solve.
If possible for you, Please Send an Example file (48_solid_spotweld) to check by me.
Bestregards
Hi Korosh,
This warning shows that the keyword is currently unsupported. You can ignore this warning.
This model can be solved in RADIOSS. Please let us know the error you are facing. Make sure that the include file (HAT_PART.inc) is also in the same folder.
Please find the attached file.
model.rar
Thank youso much for help me
I had include file (HAT_PART.inc) and also in the same folder.
I try by import your file ,but i have same Problem :
Warning:  starter Input Deck contains Keyword  //SUBMODEL/1
 which is CURRENTLY UNSUPPORTED in HM present at line number 429
is that may be for my software version ( V14-2015) ?
Bestregards
Hi Korosh,
The //SUBMODEL card is currently not supported in HyperMesh. Hence you are getting this warning.
You can ignore this and can continue solving the same in RADIOSS.
