lambefr
Viewing local coordinate systems in Hyperview
Hello, I tried a quick search but did not find my answer; sorry if it is trivial but it is causing me a hard time!
I created node reference systems in Hypermesh.  I solve my non linear problem with Radioss and my coordinate defining nodes move during the simulation (hence my coordinate systems *should* follow them).
My qyestion is: how can I make my systems visible in Hyperview 2017 so that I can see how they moves and behaves in time during the simulation?
Thanks
Thanks for your answers!
@Prakash Pagadala:
When I load the .H3D for both model and results, the "systems" tab icon is simply not in the model entity tree?  So I can't hide or unhide them?...
BUT, when I load the 0000.rad as my model and the .H3D as my results, the systems do appear and I can see them move.  Thank you Q.Nguyen-Dai for this answer!
Any reason why I don't see them when I load the .H3D in the model also?
Thanks for your support
@lambefr I didn't know that you are using RADIOSS. But with OptiStruct you can see the systems in h3d result file.I need to investigate why the issue is with RADIOSS.
