Sign in to follow this
vreddy
Finding a closed loop free edges
Yes, there is not direct but simple way
It is like this
*createmarkpanel elems 1 "Select elements:"
hm_blockerrormessages 1
catch {*findloops elems 1 0}
hm_blockerrormessages 0
if {[hm_entityinfo exist comps ^loops]} {
     #if you use hm14 or newers:
     *createmark elems 1 "by comp name" ^loops
     set FreeEdgeLoops [hm_findconnectedpatches elems 1]
     #if you use hm13 or olders:
     upgrade => version14
     #just joke! try isolate only component ^loops, and gather its elems "by attached"
Merula, Toan Nguyen and Rahul R like this
Hi tinh ,
*findloops elems 1 0   -> is not creating component named ^loops
It will work only for shell elements ??? (not for 1D)
Thank's for your reply.
Yes it works with shell Vreddy
Dont create free edges by *findedges
Use *findloops will create just loops
If you still want to use ^edges, try
*createmark elems 1 "by comp name" ^edges
set Loops [hm_findconnectedpatches elems 1]
But sometimes, free edges are not loops (example if you have a flat plate with a rib on it)
Rahul R likes this
