23 minutes ago, Q.Nguyen-Dai said:
Have a look at following commands:
  • *createnodesbetweennodes
  • *createnodesbetweennodelist
Thanks.
but this will create nodes between ....
I need to mark the middle node in a second order element.
for that I asked for that command
I have read a function that manipulate midside node, but I can't remember where it is.
anyway, try:
set Config [hm_getentityvalue elems $Elemid config 0]
switch -- $Config {
      106 {
               #tria6 elem
               foreach Node {node4.id node5.id node6.id} {
                    lappend MidSideNodes [hm_getentityvalue elems $Elemid $Node 0]
