inasiopo
MUMPS memory error - Optistruct
Dear all,
We are trying to run a very heavy model, non-linear analysis (slide contact + pretension) and quite a lot of elements.
It keeps giving us an error of not enough memory for the mumps solver. We are running on a machine with 4 cores and 64 Gb Ram. We tried all the options, (core in, core out, fixlen, len, etc..) but same error!
Is there a way to tell optistruct to use all the available ram and then use the hard drive for the rest? Or do you now of a better way to avoid this error message, and let the simulation run, even if it is going to do few days to run?
Many thanks in advance for any response and for your help and valuable time.
Dear Rahul,
I can share those files, of course. Can I please ask what is the best way to get these files to you?
Many thanks, we really appreciate your support.
Elias
As you see the below message, the required memory is simply not available on this machine (the printing is just the estimate and the actual required memory could be a bit more).
**               Windows 7  SP1 (Build 7601)  GIVE_PC01               **
**         16 CPU:  Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz          **
**                    53352 MB RAM,  66399 MB swap                    **
Recommended Memory (RAM) for Out of Core Solution       :   52361 MB
Recommended Memory (RAM) for In-Core Solution           :  196954 MB
(Note: Memory for MUMPS Solver is Included in Estimation.)
Please check if the machine with a bit more memory is available (MUMPS needs additional 1472 MB).
Also, try param,HASHASSM,yes and see if it helps.
@Rahul R I have met the problem at this time.
How to solve the problem, I also have tried -len but it still have error
Messages for the job:
 *** ERROR # 3401 ***
 System does not have enough memory available for MUMPS solver. MUMPS needs
 addtional 64328 MB. Please use a computer with bigger physical RAM.
I also set the  param,HASHASSM,yes, but it still error.
My ram is 16GB
Hi @LKZ
Can you change the directory and check if this helps?
You can use TEMPDIR command to allow OptiStruct write scratch files.
