Sign in to follow this
bmech
MFLUID
Unfortunately there is no tutorial available on MFLUID. I will check if there is a model file available which I can share with you.
If I want define a more complex surf (without use zfs)? For example a cycler with a piston (so the volume of fluid is the volume of the cylinder minus the volume of the piston)?
Thank
