I want to know what this error mean when i used comp in interface definition of contact:
ERROR id : 475
** ERROR SURFACE BUILD FROM SOLIDS PART
NON AVAILABLE OPTION /SURF/PART/Surf_ID FOR CREATING SURFACE 6
FROM A PART OF SOLIDS ;
This is an issue created to the /SURF set created in the model.
The keyword /SURF/PART/Surf_ID is available only for shells and for solids you have to use either /SURF/PART/EXT or /SURF/PART/ALL for creating the set.
Look for a surface with this label in the model file (open in textpad and manually search)
/SURF/PART/6
and change the same to:
/SURF/PART/EXT/6
Sign in to follow this
