KevinE
Composite Forming - Multilayered with Resin
Hello Forums,
I want to setup a composite forming simulation in Hyperform using the Multilayered approach but with resin in between the plies.
On the forums I found the example from the attached .rad files, but I don't really understand how it is setup.. I always thought the multilayered approach uses one blank for one ply, in this example all plies seem to be combined in one single blank and the resin components showing in the Modeltab are not even included in the User Process Tab.
I hope someone can give a short explanation or tutorial on how to properly setup the resinlayers in User Process.
Thanks
independent_layers_with_resin_new_0000.rad
independent_layers_with_resin_new_0001.rad
