Thulashi Raman
radioss explicit dynamic spring compression
Dear all,
I've given you the model setup in the attached image. Initially the assembly has to run at 2000 rpm along Z axis and then a torque of 800 Nm will be applied on the master pilot node of flange (the whole assembly is in rotating condition and then torque is applied on flange to compress the springs). This torque is an impact load acting in less than 50 ms.
Kindly help me to setup the boundary condition. Here the guide and block should not move radially outwards. Only the spring and flange will have the radial expansion effect.
19 minutes ago, Thulashi Raman said:
Dear all,
