Amar17
2D Meshing between the elements
Hello Everybody,
I am attaching the illustrative s of the problem I facing. I have a portion of the surface meshed and I want the remaining portion to be meshed. How to achieve this?
On 8/27/2017 at 1:24 AM, Q.Nguyen-Dai said:
Juste define a surface within this area and mesh it by keeping the same density. Do equivalent the nodes finally.
Thank you  Nguyen-Dai
But after doing this way, the elements on the new surface are not connected to the elements from previous surface.
Hello Amar,
You can try using the command Spline( in 2-D) with the options With/Without/Delete surface. However, before you try this, familiarize yourself with the importance of equivalence command as suggested by Q.Nguyen-Dai
Also, you may need to project the new nodes/elements on the surface, if the surface is not planar.
