I try to do the "MV-1051 - Understanding Sequential Simulation" tutorial with MotionView 2017.
It is the second tutorial where i get an error on creating a template.
This is what i write in the "Write text to solver input deck:
<Constraint_Joint
id="5000"
type="FIXED"
i_marker_id="{the_model.m_slider_track.idstring}"
j_marker_id="{the_model.m_1.idstring}"
The first marker is different from the tutorial because i type a different name. If i use the function bar and evaluate it then i can see that he found the right markers. Where is the problem in my template?
This is the error message if i check the model:
1 Error:   Syntax error in expression:
              <Constraint_Joint
              Templex error evaluating text under The Model-Fixed Joint Defn..
Finished Checking Model
Errors were detected in the model.
If i try to make the next template in the tutorial i get the same problem.
What about the variable name?
Is it same as marker name?
Can you remove "the" for I marker id function and check if that works?
I did the tutorial complete new from the beginning again. I typed the same text.
Maybe it was the same problem i had with AcuSolve. If i copy the text from the tutorial, the sign " was not the same one as the one that i type on the keyboard.
