mithunpjohn
ABORTING RUN DUE TO AN INTERNAL ERROR
 *** INTERNAL PROGRAMMING ERROR ***
   in file "dppdrv1.F", at location # 1034.
 ****  ABORTING RUN DUE TO AN INTERNAL ERROR  ****
 OptiStruct error termination report printed to file
 "opti.stat".
Someone please tell me what is the problem
opti.stat
Hi Mithun,
Can you try the same model with 2017 HyperWorks?
Looks like a programming error in 14.0 If you still face the error, please share the model file with us to investigate further.
Hi Prakash,
I tried it in HW2017 its the same, but its something else, because when i change from 'all' to 'displayed' it works and the wieder part is everything is displayed. Could you take a look at the model and also how can i upload the model so that it is only accessible to you.
Thanks in advance,
Mithun
Hi Mithun,
The error is because of huge number of design variables. We are checking with experts. I will share their suggestions and views ASAP!!!
hi, Prakash,
I have a doubt, as you know i am running a composite optimization and i am confused with the dconstraints. Currently i am using composite stresses 1, 2 and 12, but there are regions in the model ( at the joints) where the stresses are higher and this leads to constraint violation. Do you have any suggestions for the dconstraints?
Also did you have any success with the model?
cheers,
Mithun
Hi Mithun,
For internal programming error add I64 which uses 64bit solver with 2017
You can add this through PARAM>> I64SLV.
I need check the model further to understand the constraints and objectives. I will get back to you soon on this.
