Sign in to follow this
Elvis
four-point bending test
Hallo,
for the validation of my model I tried to simulate a four-point bending test with a sandwich panel. The layers are modeled with MAT1-Material and the core with MAT9ORT. Somehow, the results are not matching to the one on the testing machine of the sandwich part, which I got from a data sheet. The displacement should be about 1,5mm, but I got 18mm.
I attached my matieral card and a screenshot of the model. The engineering constants were provided from the supplier. They should be right because he sent me screenshots of his simulation, where he has a displacement of about 1mm.
Hi Elvis,
Can you cross check the unit system?
Is the force applied is in Newtons or any other units?
2 hours ago, Prakash Pagadala said:
Hi Elvis,
Hey Prakash,
yes the force is applied in Newtons (450N in total), the engineering constants in MPa.
Hi Elvis,
Is it possible to share the model file and data from the supplier?
You can use the file transfer link in my signature below.
On 31.8.2017 at 9:34 AM, Prakash Pagadala said:
Hi Elvis,
Hey Prakash,
I sent you the model file and the data sheets a few days ago. Did you check it already?
18 hours ago, Prakash Pagadala said:
Hi Elvis,
I didn't receive any file drop mail from you. Could you please share again?
Hey Prakash,
I sent you the informations again.
Thanks.
Hi Elvis,
I ran the model on 2017.2 and as it is and the result is 0.9314units of displacement in Z direction.
Which version of HW are you using?
