Abhilash Mohanta
Acusolve export problem
Hello
This query is actually related to the export problem in AcuConsole. After giving a proper mesh to the model whenever I am importing it to AcuConsole whether it is in .inp format or .nas format the Acuconsole window closes immediately and mesh_intersections.nas is generated in the saved folder. How can I overcome this problem? Further what is mesh_intersections.nas and how can I solve this?
Hi Abhilash,
if AcuConsole is creating mesh_intersections file, there must be some issues with mesh.
Reimport the mesh_intersections.nas file in HyperMesh over the original file. it will show exact location of intersections in your model.
clear these intersections then export to .nas format.
Hope it helps you.
Regards
Ravi
Hi Abhilash,
please follow below steps..
1. Open HM file : the one you prepared
2. Go to Import -->> File type  : Nastran  --->  browse and select Mesh_intersection file  --> click on import
once import is completed, go to model and check  some components has been created.
now correct these elements and export.
Regards
Ravi
