Sign in to follow this
pat_star
Message ID 205 and 207
Hi at all,
I work with RADIOSS and HyperCrash. I get the following error:
MESSAGE ID :          205
 ** RUN KILLED : ENERGY ERROR LIMIT REACHED
MESSAGE ID :          207
 ** RUN KILLED : TOTAL MASS ERROR LIMIT REACHED
What can I do or what is my fault?
Thanks for your help
I think this error results if you are using mass scaling in your model (DT/NODA/CST option) in your model and there is any factor causing the time step to decrease such as element distortion/penetration . Because the time step tends to decrease to very low values, too much mass is added to maintain the minimum time step,which results in this error. I suggest you to check for any penetrations through the interface or any element distortion happening in the model.
Rahul Ponginan likes this
