goncalop
Error 1487 - Optristruct
I'm trying to run the tutorial on this Youtube video:
When I get to the part where I run Optistruct (+-min 24), I get the following error:
 *** ERROR # 1487 *** in the input data:
 Continuation card not allowed.
Can anyone help me?
Thank you very much!
Gonçalo
Thank you for you answer Prakash! I can now run the simulation.
What I can't get it's the composite failure, strain etc... I have the Global Output Request setup as told on the tutorial.
Do you think you can further assist me?
On 9/19/2017 at 5:28 PM, Guest said:
Go to loadsteps>> Edit the first load step and remove the continuation line for STRESS and try again.
Sorry I don't know where to remove the continuation line for STRESS
may you show me in a photo?
thanks
Sorry
I got one more question in the same video(23:20-23:55)
I  do as the video and remove the continuation line for Stress
but it didn't show up at Composite Strains and Composite Stress
HELLO
Can I import my 3D CAD file into Composite analysis directly? My 3D CAD has thickness, but in HyperMesh example, it’s a pure surface. Does that mean I need to make my file a non-thickness CAD?
hello Hyperman
I've prepared another non-thickness CAD with surface only.
When I pre mesh, I can see the whole surface is meshed, but after I click "return", there's some area lost the mesh
 how can i fixed it?  thanks
Hi Hyperman,
1. Can I set force and SPC on the modal surface like picture below?
(I find an example at 42:42 in this video,
2. I've already checked the mesh, and it is there. But after I put composite laminate on my model, it's broken like this
3. However, I skip this problem and proceed to click "OptiStruct", there are lots of Error#15.
I'll be really appreciate if you can check my file in the link below
(https://)
Thank you
1. Constraints and loads applied on single nodes will cause stress singularity. For more details refer to:
https://www.comsol.com/blogs/singularities-in-finite-element-models-dealing-with-red-spots/
2. and 3. are due to bad mesh. You should remesh the model  using the these tools:
  • Geom>autocleanup to clean up the geometry
  • 2D>automesh>QI  optimize (F12) to mesh using quality criteria
  • 2D>elem cleanup
  • 2D>qualityindex
  • tool>check elems>2D (F10) to check elements
There are more then 4 million elements in the model you shared. Reduce the element count (increase element size), unless you have access to supercomputer to solve this model in a reasonable time.
There are some great learning materials from Altair university- Practical Aspects of Finite Element Simulation is a good starting point.
https://altairuniversity.com/free-ebooks-2/
Check the following Youtube channels:
Altair University
Altair India Student Contest
ELEATION By Apoorv Bapat
https://altairuniversity.com/wp-content/uploads/2012/04/HM_Geometry_extract.pdf
https://altairuniversity.com/wp-content/uploads/2014/02/HM_Automeshingintro.pdf
https://connect.altair.com/CP/SA/training/self_paced/aero_v13/PDF/chapter4_demonstration.pdf
The Like button is an easy way to show appreciation for a post ;)
getting this error again and again what is error and how to resolve please help
Messages for the job:
 *** See next message about line 16 from file:
     C:/Users/Desktop/air.fem
  "STRESS(COMPLEX,ALL,CENTER,,,,,"
