Hi All,
I am trying to write a tcl/tk script wherein I need to export .csv for each component's Advanced Query results.
I am not able to find the handle to to control this option. I have attached the screenshot for clear understanding
of the problem.
Thanks and regards.
Saumya Mishra
Hello Saumya,
You will have to create appropriate selection set for the advanced query.
Writing to file can be done as below:
hwi GetSessionHandle mySessionName
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myModelName GetQueryCtrlHandle myQueryName
myModelName GetSelectionSetHandle mySetName [myModelName
AddSelectionSet  element]
mySetName Add all
myResultName SetCurrentSimulation 1
myQueryName SetDataSourceProperty result datatype Stress
myQueryName SetDataSourceProperty result shelllayer Upper
myQueryName SetQuery "element.id,result.value"
myQueryName SetSelectionSet [mySetName GetID];
myQueryName WriteData {c:/temp/d.txt};
refer: https://connect.altair.com/CP/kb-view.html?kb=86072
tinh likes this
On 9/21/2017 at 4:02 PM, Saumya Mishra said:
Hi All,
of the problem.
Thanks and regards.
Saumya Mishra
hi saumya,
Did you find a way to do it. I am facing a similar problem.
Thanks and regards,
Rahul.
