josherrod2
Exported PDF in Virtual Wind Tunnel
I have a problem with the virtual wind tunnel. When I do the test it works perfectly but at 80% it does not progress and it closes the hw.exe. At that point you should open Acufieldview to make the captures that will be exported in the PDF. But the essay stays there and does not export the PDF. If I look in the folder Run Patch the test is finished but without the PDF. In the folder I can find all the results of the coefficients but not the PDF.
Would anyone know how to solve this problem?
I attach files to explain better.
Thanks for your help.
cilindro.nas
On 26/9/2017 at 11:39 AM, ydigit said:
Could you post your vwtAnalysis.1.Log file? Does AcuSolve end normally or is it an abrupt end? It might be that the solver runs and only the post processing does not happen.
Just at 80% the trial does not progress. I have already tested vwtanalysis.log in AcufieldView and it works correctly. The only bug is that the PDF of the report does not appear.
Currently I'm also facing same issue. Was it resolve in your case. If so, let me know how to fix it. Also I'm attaching VWT ruining status snap below.
Thanks
GetFileAttachment?id=AAMkADFjZGI5NGE3LTY0MGEtNGNhNC04NWEyLTQyNDg0OTg4ODVjYQBGAAAAAADrv9LQ510rSIST8o2szMldBwDMQgyiSo8HSqdwFgIicQu7AAAAAAEJAABqGWVtXSPCT5acMS1HuXpqAACtNtpMAAABEgAQANI7aXtGjGVOp3%2BKQUw%2F0Qw%3D&X-OWA-CANARY=6bgWpIJGC0OcjQyoetjVkAC0RrXqINUYle2K6CscoD4I_eWJiI5yyCplwisW0hsEZ4rPJIrfoDM.&isImagePreview=True
cilindro.nas
Please check the file  \HW2017.2\acusolve\win64\doc\texlive_install_windows.txt in your installation folder for instructions about how to download & install TexLive. Also the release notes of AcuSolve 2017.2 mention about TexLive.
Just to complete my previous post. VWT uses AcuReport to generate the pdf result file. This AcuReport requires TexLive, that is not shipped with AcuSolve 2017.2 and needs to be installed to get the pdf report.
