Muge Candogan
COG constraint in optimization
I am working on an optimization problem and COG is one of my constraints.
The COG is defined in 3 ( x,y,z ) coordinates but while assigning the constraint,  I am asked to enter only 1 value for upper and lower limit each. When I enter a value, how can I define which axis it will be applied to?
Thanks,
Muge Candogan
Hi @Muge Candogan
 You can define it for three directions X,Y and Z respectively.
Later you can define the constraints for these responses through dconstraints panel.
Hello Prakash,
Yes I used the dconstraints panel but the panel only asks for 1 value instead of 3 (x,y,z). How can I define which coordinate it is when I enter a value?
Thank you,
Muge Candogan
