Sign in to follow this
Mike30
Apply moment on axis
Dear Sir,
I would like to apply a moment on the entire outer surface of the model attached (hollow cylinder).
I know that normally a moment have to be applied on an RB3 element.
I created an RBE3 element along the central axis and then connected it to all the nodes on the outer surface (see attached file).
Would this make sense? I am not sure that every nodes are then subjected to the same condition.
Is there a better way to apply the moment on an entire axis and not just a point?
Thank you in advance
moment-along-axis-1.hm
Hi Mike,
Would be better if you have material data with MPA or N/mm, Tonnes or Kg/mm^3 when you have your load components in N and mm which maintains unit consistency and results easily readable and understandable.
