Sign in to follow this
dhananjay1308
rbe2 and rbe3 connector
1-D/connector/seam
a) I want to transform load and displacement from one component to other as shown below without any input property.
in seam weld which type should be prefer.?
b)also in 3-D both the component having a surface contact because of mid-surface there is some gap is obtained between these two component. Is there any need to give contacts between these two components.?
