Sign in to follow this
Mubeen
Tetra Mesh - Parameters String
Hi all,
I have a question after reading the documentation:
for tetra meshing using tcl command *tetmesh the script needs to use strings containing various mesh controls and parameters, e.g. "tet: ...", "2d: ...", "size_ctrl: ...", and "pars: ..."
I am using following parameters in the last string "pars":
 "pars: vol_skew=0.8  tet_clps=0.2  aspect=6 Skew=30 vol_ar=5"
However, when I run the script, Hypermesh simply fails to recognize this string, and terminates :(
*createstringarray 2  "tet: 35 $growth_rate 2 $max_size 0.8 2 0" "2d: $elem_order $elem_type 1 $elem_size_2d $min_size_2d 30 1" "pars: vol_skew=0.8  tet_clps=0.2  aspect=6 Skew=30 vol_ar=5"
*tetmesh solids 1 0 elements 0 -1 1 3
For further reference kindly see the online documentation about tetmesh:
http://www.altairhyperworks.com/hwhelp/Altair/hw12.0/help//hwdref/hwdref.htm?_tetmesh.htm
Anyone with some hints to the reasons for failure of this string, kindly help.
Best regards,
Mubeen.
Hi tinh,
thanks for the reply, I replaced " *createstringarray 2" with "*createstringarray 3", but the problem is not resolved :( i.e.
*createstringarray 3  "tet: 35 $growth_rate 2 $max_size 0.8 2 0" "2d: $elem_order $elem_type 1 $elem_size_2d $min_size_2d 30 1" "pars: vol_skew=0.8  tet_clps=0.2  aspect=6 Skew=30 vol_ar=5"
doesn't work either.
I tried something strange, instead. I appended the quality parameters string directly to the *tetmesh command
*tetmesh solids 1 0 elements 0 -1 1 2 "pars: vol_skew=0.8  tet_clps=0.2  aspect=6 Skew=30 vol_ar=5"
This way, there is no error shown by Hypermesh, but I am not sure if the string parameters were used by Hypermesh during the meshing.
hi Mubeen
your string array has 3 strings
so try replace "*createstringarray 2" to "*createstringarray 3"
