Sign in to follow this
leslie dean brown
Radial and planar symmetry?
I am investigating the design of a simple wheel rim,
I see that when radial symmetry is applied, planar symmetry cannot be simultaneously applied. When a different symmetry is applied, the other one is lost. It's either one or the other.
That seems strange as I want the inner and outer sides of the rim to be symmetrical as well as the radial symmetry... because it's not for a car or something complicated, it's just a basic wheel.
Is that right?
Radial symmetry should suffice, you can follow the tutorial here
https://altairuniversity.com/conceptual-design-of-a-3-wheeler-motorbike/conceptual-design-of-a-3-wheeler-motorbike-wheel-rim-topology-optimization/
using extrusion manufacturing constraint can help if you need the shape to have the same cross section through and through...
Rahul R likes this
