Sign in to follow this
Daivd Kang
Delete sub-layer element
Dear all:
I don't know the reason why there are two layers elements generated in this area. I want to delete the small sub-layer one (The element in Figure 2 is what I want to delete). How can I do that? Thanks~
BR, Yuchi Kang
Hi Yuchi,
Is there any small patch like surface where this element is created?.
Did you try to delete this element (F2>>select element>>delete)?.
2 hours ago, George P Johnson said:
Hi Yuchi,
Thanks for your reply. There is no small patch in this region. I used to translate an element but made a mistake, which causes a small element in this region. I want to delete this element but I can't choose this element because there are two layers elements in this region. I don't know how to mask the top layer elements. Hopes for ur reply. Thanks again.
hoo
3 hours ago, George P Johnson said:
Hi Yuchi,
The problem was fixed. I use F5
