Sign in to follow this
RishabhAwasthi
Writing data from array object into a text File
Hii,
I am trying to write a .txt file which contains element id's from a specific element group. I referred documentation of javascript but they were mainly focused on web application development and using those methods to write data didn't work in Simlab's JavaScript Interpreter . Is their a way to do that in Simlab itself
Regards
Rishabh
Currently there is no options to export only element id in .txt file from element group. But we can export the element id's along with the corresponding node id's in .csv format from selected entity.
Please follow below steps to get it.
1. Go to File > Export > Other > CSV
2. Give file name
3. Pick only element toggle in dialog
4. Select entity like elements / faces
5. Click Ok.
Hope this will help you.
Rahul R and Louis Carlioz like this
