Saving Material Without Performance Loss
Challenge
  • Reducing the weight without loss of usability and strength
  • Optimizing the manufacturing process
Solution
  • Injection molding simulation to optimize the part production and to create the fiber orientation for the new designed part
  • Taking into account these results to perform most realistic mechanical simulation
Results
  • Significant material and cost savings due to optimized geometry
  • Faster and more economic production process
valdir likes this
Challenge
  • Realistic material behavior of injection molded fiber-reinforced plastics
  • Reduce weight by metal replacement
Solution
  • Converse mapping capabilities to assign fiber orientation to the mechanical model
  • Converse material database for direction dependent thermo-mechanical material properties
Results
  • More realistic simulation of parts compared to isotropic approaches
  • Consideration of injection molding process on the mechanical part behavior
Challenge
  • Detect weak areas due to weld lines
  • Estimate the influence on the part strength
Solution
  • Converse mapping capabilities in order to assign weld line areas and flow angle to the mechanical model
Results
  • Optimized manufacturing process
  • Knowledge of local varying component strength
valdir likes this
