Sign in to follow this
bmech
Damping
Hi
If is apPlied SDAMPING (no CRIT) as law with a value of 0.08 in a certain range only
and param, G 0.08...what happens? in the defined range of frequency is considerend only SDAMPING or G.
Regards
If you are not using Modal transient, modal freq or complex eigenvalue analysis types then SDAMPING is not considered.
the analysis is a modal frequency response.
SDAMPING is applied for a certain range of frequencies. So in this range is considered only SDAMPING or is added/considered the parameter G?
Regards
I tried with SDAMP with TYPE set to CRIT and with G and my finding is that the factors from both SDAMP and G are considered.
Thanks, I did the same thing. It's really dangerous thing, this means that if you want use SDAMPING only for a specific range, you can't use param,G for the others.
Or if you have different loadcase you have to define SDAMPING for each loadcase
