Sign in to follow this
Oli
Two SPCD to one
I want to transfer Displacements from a model to a submodel.
I used "fields" to Import the .op2 file and then Realization to create SPCD's (one for the Displacement(x,y,z) and one for the Rotation(x,y,z)). I used the Card Image SPCADD to combine both.
Then i created SPC load collector for all six DOF at the nodes where the SPCD's are.
Then i created a load Step and put at subcase Definition SPC to SPC and SPCD to LOAD.
If i start calculation i get the error: "* ERROR # 1908 *** Case Control data LOAD=4 is not referenced by any bulk data relevant for used subcase type." (LOAD 4 is the SPCADD load collector)
So is it not possible to Combine SPCD's with SPCADD?
How can I do it instead?
If it helps i can upload the file?
See the Picture below.
I just masked some SPC/SPCD's to show them all with their DOF's but actually at each Node are 2 SPCD's (Displacement and Rotation) and the SPC with all six DOF's
Hi @Oli
One way is to have both SPCDs in one load collector or run an analysis and get the grid point force and then use the LOAD card image to add forces from both SPCDs
